Hi there,
I have the above monitor, new to me. I had to swap the flyback on it and it's now giving me a great image, however, I've noticed something with the audio which I'm not sure is normal for these or not.
Basically no matter if there's an audio source connected or not, there's a very audible hissing/rushing noise from the speakers. Audio itself is working fine and sounds good, no crackling etc, and responds normally to the volume control, however the background noise I describe does not. It's definitely related to the speakers, as if I disconnect them from the main board it disappears, which is also the case if I plug something into the 3.5mm jack.
My guess is this isn't normal, only because I also own a CM8833 MK2 and MK1 both of which doesn't exhibit this behaviour, but I'd love to confirm this or not before I go chasing it.
Thank you.
Thank you.
