inotarobot
Again do I keep or part with them to some with a machine that uses them
They are beautiful boards. Do you have (or plan to have) any equipment that can make use of it? If so, keep it. If not, sell it to someone who really wants it and use the funds to acquire something you need/want.
A bit of googling and ... 50-17457-01 is the PCB fab of assembly 54-17458-01 which is T2015 CPU Module AKA Dec VAX 6410 CPU module.
Seems reasonable given the form factor and the six large chips with heatsinks.
Do I also assume correctly that they maybe be NOS considering there appears No connector soldered in on that edge with what appears to be 2 rows of 2 through gold plated holes but with 2 rows of square gold plated pads as well between them?
That is the XMI bus connection in these machines. No soldering required. Example backplane picture:
