Ellron_Cupboard
Hello,
I've been messing around with this board for some time on the side. and have yet to get it working, so thought id toss this out there and see if anyone has any ideas.
its a TMC pci54its v2.0 board with an intel 430FX chipset. essentially its unable to initialize the graphics card (one long,two short beeps w/ Award bios or 8 beeps with AMI bios.) i've tried about 7 different video cards in this thing to no avail, 4 16bit isa cards & 3 pci (early) cards.
the Award bios, with only the video card + post card in it will beep (as described above) and halt on floppy drive failure, following one single high and one single low beep (i think this is a system halt noise). With award, it will just continue to cycle on 8 beeps, but also halt at the floppy drive initialization.
now when i hook up a floppy drive and insert a boot disk, with Award it will actually boot off the DOS disk (still have the one long, two short beeps) and with a keyboard plugged in, i can type some basic commands (a: ; dir , etc) and i can hear the head seek -- so i'm fairly sure its actually booted into DOS. ctrl-alt-del also reboots PC at this point too. note that caps lock, num lock , scroll lock doesn't seem to do anything.
with the AMI bios + floppy + boot disk, it cycles between F0 and F1 for post codes beeping indefinitely.
i do know that all video cards work (tested in my other build with a 430HX chipset) along with the Dallas RTC ( cr2032 modded ).
so i guess it seems like this motherboard is booting, but for whatever reason isnt able to identify anything on the PCI or ISA bus w/ exception to the post card displaying post codes.
to date, i've used deoxit on the pci and isa slots, reflowed all pci/isa solder joints. verified 33mhz on the pci bus along with all voltages (save 3.3v). i've sourced about 6 different bios images (586 PnP bios') from the TMC website (via wayback machine). verified the 14mhz crystal going into the clock chip along with some other odds and ends.
also, maybe worth noting. regardless of if a video card is inserted or not. it will always beep as described above. i would expect maybe one long, 3 short beeps with no card installed. i'd also expect the system to halt when it cant identify or initialize a video card -- but alas it doesn't seem to do any of that.
i recently saw a thread on here discussing the 430NX chipset needing a specific type of dallas RTC config to function properly. i wonder if the 430FX is similar?
after writing this out it almost seems like this mobo is a good candidate for the wall of failure.
anyways, thanks!
anyways, thanks!
