4K languages for the PDP 8
silcreval
UK
What languages were available for the PDP 8 that ran in 4k. I know about the FORTRAN subset compiler, but was there ever a TINY BASIC ?
Edusystem 5 Basic
Edusystem 10 Basic
Focal Amity
That's what we ran on the PDP-8/L at my school in 1972 - 1975.
Do you have the papertapes for this?
I appear to have a functioning copy (as well as a couple of less functional ones) of Amity Focal on my site. It's decus-focal8-136:
I don't have write-up or source. From observation, starting at 00200 will halt at 04006 for some reason, and if you continue the introductory dialogue begins. (What is the correct starting procedure?)
I have placeholders for the Edusystem 5 and 10 stuff, but not the actual stuff.
Vince
An inspection of the disassembly suggests that 0200 is indeed the correct starting address. There is a check, however to see that the switches are non-zero. If they are zero, the HLT at 4006 is taken, otherwise it is skipped. Not sure what that's about.
Vince
Thank you both for the pointers. EAE-dependency, twice, understandable given limited memory, but unfortunate just the same. Has anyone designed/built a replacement for the venerable EAE (KE8-E)? Maybe needs a separate thread if there is a yabut, etc.
There are software emulators, and they aren't even that large, but in 4K you may not want to spend the memory.
I started a KE8E implementation where each board is reimplemented with a 5V CPLD. The PCB has two sites, and you can populate either one or both. I've run my schematic-to-verilog scripts, but I've not yet made the time to actually debug the resulting Verilog.
Vince
Seems so, but they never responded to any mail I send.
Hopefully a friend will do some research in BASIC there in future, then maybe we have a chance to get a copy.
Maybe somebody has better contacts?
If it's just for the multiply/divide and/or extra registers, it wouldn't be too difficult to modify - but it would increase the memory requirements and reduce performance.
