modem7
10k Member
Use of Advanced Diagnostics to low-level format
[Advanced Diagnostics for 5150/5160, not 5170]
a. Boot from the ADVANCED DIAGNOSTICS floppy (version 2.02 or later).
b. At the first menu, choose 0 (for System Checkout).
c. WAIT .. there will be a long period, including a time of no diskette activity. Be patient.
d. Enter Y [ the list is correct ]
e. Enter 0 [ to select option 0 - RUN TESTS ONE TIME ]
f. Enter 17 [ to select the Fixed Disk ]
g. Enter 2 [ to select option 2 - FORMAT FIXED DISK ]
h. Enter C [ to select drive C: ]
i. Enter Y
Low-level formatting will start. You will see the hard drive's access light turn on, and stay on for the duration of the format. Low-level formatting will take a few minutes.
i. Enter Y
