Anonymous Coward
I seem to recall somebody had figured out a way to modify standard 256kb SIMMs to work in the 5162. Does anyone remember the link to the post that describes how to do it?
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
The ninth chip is for parity.I believe you need to use 9 chip SIMMs to meet refresh timing requirements.
Does anyone know for fact whether or not 'standard' 256KB SIMM's will work, rather than 'best of recall'? Surely, a 5162 owner has either been forced to try it, or experimented. I known that member 'Dani G' would also like to know of any certainty (thread 73757).
AC,
Stay safe over there.
Might do, I just finished testing a pair of 3 chip simm's in my 5162, P/N SJ-2563N, 70ns chips, Counted up to 640k and ran Checkit 3 memory test in thorough mode twice and passed with no problems. My 5162 is running the AMI bios. Maybe the IBM bios would choke on it ??.What I meant was 3-chip parity SIMMs will not work. Like these:View attachment 60138
I actually installed DOS 6.22 and Checkit 3 on a spare clean CF with those simm's in the 5162, It went fine but i'm not testing anymore i was getting a bit concerned about damaging the Simm sockets, Rather a tight fit and didn't want to break the retainers. The original Simms have probably been in there since new.
I have not been able to fault the 9 chip 256k pair of simms i tested or the 3 chip 256k pair of simms, I ran checkit 3 and Micro scope memory test with 100% pass, Today i removed the AMI Bios Roms and Re-fitted the original IBM Bios ROMs and with the 3 chip simms in i ran the memory tests with no problems, I installed the XUB r602 and it's also running fine, I have not been able to fault it yet but will play more over the next few days.
