Harry.Speer
- Joined
- Dec 14, 2022
- Messages
- 32
I've decided to use VME bus - or rather a subset of VME - as presented on the Tom Storey GitHub here: https://github.com/tomstorey/COMET
He's using only the signals needed for a 68000 16-bit Data Bus and Addresses from A1 to A23 - IIRC. Not intended for multiple CPU's but allowing for use of DMA on the bus for a Slave Card like Floppy Controller or Hard Drive Controller. He's put up an 8-slots VME Backplane and also both a 100mm x 160mm VME Prototype Card and also a 100mm x 220mm VME Prototype Card. So I'm thinking use a PCB House to run a few of each and then get to work.
His Backplane-8 - 8 VME Slots here: https://github.com/tomstorey/COMET/tree/master/VME_Backplane_8ActPas
His Prototype 160 Card here: https://github.com/tomstorey/COMET/tree/master/VME_Protoboard_160
His Prototype 220 Card here: https://github.com/tomstorey/COMET/tree/master/VME_Protoboard_220
Does anyone here have experience either with HomeBrew 68k SBC projects and / or Someone with experience working with the VME Bus ??
This is my first HomeBrew Computer and I've chosen the "smallest" of the 68000-Family of CPU's. Includes the PLCC 68008 via a PLCC to DIP package converter card, a UV EPROM or a EEPROM or a 512k x 8 Flash Chip with a Read-Only Jumper in place to prevent accidental writes.
Then a Single Static RAM 512k x 8 - One Chip !!! and then the usual 68681 or equivalent DUART, with MAX232-Family Chips for RS232 levels shifting. Possibly a 68230 PIT, a Battery-Backed RTC, a "ticker" clock, and Lastly or Firstly a Power Supervisor Chip like ADM705 and a Traditional 555 Timer for the Pair o f /RESET and /HALT through Open-Collector Buffer or Inverter with each having a Pull-Up Resistor and a Buffered LED for Each. A few other well-placed LED's like Address Line A23 and A22 and so on. A Debug Display can be very useful.
So anyone with experience, please chime in !! Harry S. Speer
