OK, some updates on resurrecting the WS030 prototype. I have a 16bit Paradise, but it doesn't seem to recognize the card. I have a multi-io card; the prom software is supposed to look for a COM1 serial port if it can't find the VGA card, but so far no activity. I also have a 1Mx32 SIMM module for the memory. it might be time to pull out the logic analyzer and see what is happening at boot. I have LEDs that display the CPU status (super mode, and interrupt level) and it certainly does stuff when you hit the reset, and then stops, presumably because it got lost and got a double bus error or something. I'm going to validate the image in the prom I have (it's from 30+ years ago) to see if there is some bit-rot going on. I have an image and sources I can compile, so I can burn some new proms.
as a side note, I did find some of the sources to the modified Minix that ran on it, once the hardware is running, I'll see what needs to be done to build a bootable image.
also, recapturing the schematics and layout in Kicad.
