Ahhh, hope you don't feel too bad. I've not had it yet (or more likely, had it and not noticed. Just remembered I was called 'patient zero' in 2020 !,but I was only ill for a day and didn't have a cough).
The DPS system performed well during the heatwave, fortunately all the chillers were working. It was the UPS systems that were complaining. In the control room though, we were shivering a little as the A/C was running a little too efficiently. Must have been the only cold people in the country.
Yes, without PETTESTER it would have been very very difficult to identify the fault. Its a superb tool.
Its happily running DRAM tests now but (there is always a but)
With the Edit ROM back in, booting gives the normal message but pressing return causes it to crash, sometimes keys give what you would expect, other boots they give graphics characters. Though that could be a keyboard problem, all keys seem to respond as expected within PETTESTER.
All the installed ROM's during PETTEST give the right checksums (4168 5960 a425 & cf19), so I'm assuming they are ok. Will need to test the Edit ROM to make sure that is ok.
I believe that typing is done in screen memory then tokenised and moved to main memory on pressing enter ?
Edit ROM check first then any ideas ?
I will probably burn a copy of the 901474-04 program into a 2532 EPROM as well (but, doh, of course I can use a 2716 for this as well
LATE ENTRY
The DRAM test is now throwing up an error after running sometime with the case closed. Showing error
Initially showing
"Mem fail 3 1 4558 10 10!"
now consistently showing
"Mem fail 3 1 4558 10 1f!"
So in the upper 16K bank of the memory and bitmask of 0001 0000 so bit 4 so probably UA10 has gone south. Dave, whats the significance of the 'faulting data byte' and that it changed from 10 to 1F ?
