Peter z80.eu
- Joined
- Apr 21, 2016
- Messages
- 84
I was wondering how "big" a power supply must be to deliver enough power to a defined constellation of hardware.
That means:
A motherboard, a CPU ( must be ;-) ), a common/usual amount of memory (RAM), a floppy drive (3.5" or 5.25"), a Compact Flash card as an IDE HDD.
I am asking that because I got an almost empty vintage AT (clone) computer case with a 150W power supply.
My idea is to build with that case and power supply a new working PC.
I am free to select the era, I just have to use a mainboard with "baby AT size".
So I was thinking first about a Turbo XT board, a V20 CPU, 640KB (DIL) RAM, a 360KB floppy drive, a XT-IDE card with a small CF card as HDD. And an ISA VGA card like a ET4000.
BUT.
As far as I can measure it (with already build/existing PCs), there is not really a big difference in terms of power consumption, if you choose PC hardware 'til the Pentium III era.
Explanation and my question at the end:
CPU power consumption differs between 3-5 Watt for the very first Intel x86 processors (8088, V20) to somewhat between 15-25 Watt for the Pentium II era (excluding the top models with the highest frequency).
I have no values for the mainboard consumption, but the shrinking process for the circuit technology helps to reduce the power consumption, means older mainboards not really drain less power.
RAM does consume more power if the access times are going down (in nanoseconds), but this increase is moderate, too.
If you don't choose a high end PCI 3D accelerator card, instead, just an ATI RAGE XL with 8MB, this should be also acceptable.
And last but not least if you take a CF card as a HDD replacement, you will be for sure on the safe side, too.
So my idea was to take instead a Socket-7-Mainboard with a Pentium 200MMX (or similar), about 64MB RAM with FP-SIMMs, a 1.44MB floppy drive, and the already mentioned CF card (but with more capacity).
For my targeted 150W power supply, this must be still manageable, and there must be still from for an upgrade (e.g. a second floppy drive).
What do you think ?
That means:
BUT.
What do you think ?
