Caluser2000
Banned
Some time ago I picked up an Acorn Archedes 410/1 from our local NZ major Action site. There was no keyboard or mouse with is whch was not a problem as had a couple from an Acorn A4000 purchase. The system has had an ARM3 cpu upgrade as well as a ram upgrade from the original 1meg. It also has RiscOS 3.1 ROMs fitted so upgraded from RscOS 2 Arthur. It has the "green on sync" vga issue which is well documented and I intend on rectifying. It also needed a bit of a clean up.
So far I've cleaned up front plastics as well as fitted a switch for correcting the sync on green vga issue. I've also replaced the case fan filter from which was disintergrating as well as clean the fan itself, fitted a psu fan, tidied up rear lh bottom of the housing under the battery holder to remove some minor battery corrosion. The CMOS battery holder is not situated on the mobo so no possibility of the mobo being damaged.
