I installed some new ram modules. The machine boots and I get a prompt! I can run DIR and things like that. The machine works for a few minutes and then freezes up. I still get the parity error light when it loads CPM. My computer skills are not amazing but I did a little investigating and found an curious problem:
I found I can manipulate the memory banks using the super six monitor and the In and Out commands. The memory of each bank is split into 16K chunks that can be turned on and off. If I turn on bank 1 chunks 0,1,2 and leave the top chunk on bank 0 (where the ERPOM is), I can fill memory and it seems to be fine and everything is stable, filling and viewing. I think the parity errors are happening in the top chunk of bank 1.
I would assume that either there is still bad ram in that area, or the circuitry to switch in that chunk of bank 1, or to turn off that chunk is bank 0 is not working.
Should I order more ram and keep trying to replace bad dram chips, or do I pursue a bad chip in the bank selection circuitry?
I always appreciate that advice and thanks for all of the help.
