Endersending
I think the sawtooth waves are truly there. The scope and probe are designed for 500MHZ and I am probing a 800KHz signal. I am an amateur so I will check and make sure I have my coupling set correct. I am also grounding the probe to the voltage regulator which maybe I should be ground directly to the chip's ground pin. I have an older Tek scope but it has some problems. The CRT lights up for maybe 10 seconds and then slowly fades away. turning it off and letting sit for a few minutes and turning it back on it repeats the same problem.
I think the sawtooths are coming from a bad chip but I have not come across the right situation to pin point it. There are (2) 74ls245's that I am planning on replacing when the new chips arrive. I am also attributing the 'working but won't boot floppy' issue with the resistor network that I snipped because of how warm it was getting. I think this was the pull-ups for the floppy cable. I have a replacement for that in the mail too.
I am still feeling like the sawtooth waves are part of the dram refresh the way the are there between the normal activity of the lines. Just a hunch which may be pointing me in the wrong direction.
Once I replace the 245's and resistor network I will do more testing and report what I find.
Right now my projection is to start replacing chips and brute force with parts.
