WimWalther
The Tandy 1000 machines like the ex & hx models lack a hardware reset button. I'd really like to add one to save wear & tear on the power switch and PSU components. So is this as simple as perhaps...
Plus connector RESET pin -> 1K resistor -> 10uF cap to GND -> SPST Mom. from cap + to GND.
I may have the cap on the wrong side of the 1K.. not quite sure. Should it be connected directly to the RESET pin? It works pretty much the same either way - push the switch, which drains the cap leaving you with a 1K pulldown on RESET.
Thoughts?
Thoughts?
