Hi all,
I have a very nice (condition wise) Dell D1626HT which I bought from someone who had found it in their loft.
I have been using it on and off for the past couple of weeks.
When I first started using it, it would click and "flicker" the screen occasionally, but this reduced in frequency over time until it was only a very occasional thing.
Unfortunately now it seems like it is now not registering inputs correctly. I think it is going to "no signal" when it sees an image above a certain resolution.
At first it would display the desktop just fine, but then it would cut out and go to the "no input" screen with the same relay click you hear when the resolution changes. If I power cycled the monitor, the picture would come back, but then it would go again after maybe 10 seconds.
Currently when I power it on it displays the POST screen, then goes to no input, then comes back at the OS loading screen, then goes back to no input again. So it seems like it is relatively happy displaying those low resolution images. I can now no longer get it to display my desktop, which is only set to 1280x1024, bearing in mind this monitor is theoretically capable of displaying 2048x1536.
I bought a VGA to BNC cable to see if it behaves any differently when connected via the BNC connectors, and it does, it sometimes shows the "no input" screen, but most of the time it just displays a completely blank screen, as though it sees a signal but cannot display it.
I have tried plugging different devices into it, as well as different GPUs in the PC it is usually connected to, with no success.
Here is a video of what it is doing on a VGA signal: (please ignore the issue with the colours, that is because of the VGA cable, I was trying a different one which happens to need a clean)
I am fairly confident in opening it up and taking a look inside, my main concern is honestly being careful not to damage the plastics in doing so.
From what I can see through the grilles with a torch, it is fairly grubby inside, so the first thing I am going to do is give everything a clean, and then inspect it for physically damaged components or obvious solder cracking.
I would greatly appreciate any input from folks more knowledgeable about such things, in letting me know what else to try or to check.
I have a multimeter but I don't have an oscilloscope or any specialist test equipment.
Lastly on the slim chance someone reading this is local and would be willing to take a look at it in person, I am in the UK, near Norwich.
Many thanks in advance!
