>Interesting... I wonder if the disk then is trying to set a baud rate my machine can't even handle?
It's possible although I think the TTYS file doesn't come into play until after CCPM.SYS is launched. Try pressing ctrl-c when it hangs. Sometimes that takes it back to a cold boot routine.
Or blindly type 40FH then return. Can you change the baud in your terminal to 9600 ?
I've tried every baud rate, 19.2K is the only one that displays anything at all (and it stops displaying when the floppy loader executes). Blindly typing does nothing, and neither does ctrl-c.
EDIT: Well, anything coherent anyway. I sometimes get garbage at some of the other baud rates, but it's just a corrupted version of the text I've already seen. No prompt.
