GearTechWolf
Came from a C64 epoxy-brick PS but didn't survive disassembly, need data so I can replace with a comparable/equivalent part.
Alternately, going by the rest of the circuit, would the pin-out I've marked be correct?
The broken part-
The board with crude annotations-
Once I get an applicable regulator subbed in, I can do a smoke-test with mostly original components! (not attaching it to any computer until I build the saver circuit)
If it passes that, I'll load-test with a dummy load and see how it fares.
Thanks for any help!
The broken part-
