Ok, so we went from constant rain back into the freezing temps again and I could do the repairs on the generator.
The work being done was 2 new sparkplugs gapped at 040, oil change, oil filter change, Air filter change, 4 new hose clamps to replace leaky ones on oil cooler lines, and brand new Internstate battery.
All of the work was obviously straightforward except for the stock hose clamps. They seem to be pinch/crimped on and I dont have whatever tool is necessary to clip them off. So fighting to get them off involved a bunch of skinned knuckles. I will check back every week or so and look for any new evidence of oil leaks.
Its too cold to deal with the corrosion and rust so I used a chisel to remove the bubbled paint and a wire brush and vacuum to remove the trapped rust and get it down to a cleaner surface. I used some oil over all the rust until I can better deal with it in the spring.
I also bought a battery tray. Here is where I mess up big time. I put a small 1/4 inch layer of speedy dry on the bottom of the battery tray. You know, because I am concerned about further corrosion. So upon fitting the new battery and firing it up after all the maintenance and repairs were done I was greeted to a wind vortex that took all the Speedy dry material and shot it all over every bit of the inside of the generator... Now its an engine that uses lubricating oil.. And I oiled the battery compartment.. You can imagine the mess and the horror and the obscenities that were spewed out at that point. I had to take the battery out and vacuum up what I could.. But any surface which had the tiniest bit of dirt or oil caused the Speedy dry to cling to it. It took an hour of using paper towel and surface cleaner to wipe down all the surfaces and the engine. I used my office Toner vac wtih a long thin attachment to get hard to reach places. There are still tons of small areas I cant get to with speedy dry. My once relatively pristine generator engine.. is a mess.
That was a stupid stupid thing I had done. Well Lesson learned.. Dont do do that......
I also noticed someone had cut the positive battery terminal back and fitted a new end on. But its and automotive end and a bit too large, so of course the positive cable popped out when I was working on it and the 240V wire was shorting on the inside of the chassis.. So that was nice. I had to take the connector apart and fit it properly. I will needto either replace the entire positive cable to the starter (just to get the proper length back) or replace with a better connector in the spring.
I put it all back together just as the sun was starting to set and took a video. Other than the dumb issues I mentioned its sounding like it used to. I realize I must have 70 to 80 feet of Propane line back to the tanks so the weekly prime is never instant for those of you wondering why it doesnt start right away. The gas pressure regulator may need adjustment, I dont know. It was done in 2018.
Anyway here is a video of me starting the unit after all is said and done, stopping it, then restarting it again. What do you think? How does it sound?
