Wawavoun
Hello there,
I try to run Apollo emulation in MAME. I assume Mame is ok because Amstrad 6128 emulation with cpm run smoothly.
I follow this thread which look cool and easy :
https://forums.bannister.org/ubbthreads.php?ubb=showflat&Number=94705#Post94705
I found the required roms and the OS tape backup...
Everything run quietly (config, invol, calendar) at the beginning
Domain_os start to copy installation files to hdd. He copy a lot and then crash...
I just see a brief message at the beginning of the copy that he skip sysboot because already found on the volume (look strange because the volume is just newly formatted).
This occur in service mode. In normal mode the system reboot after copy (dont know if this is normal or if the same crash that in service mode give this result). After the reboot he complain lacking sysboot...
I try several time with the same result.
Any idea what should I do...
It s a first step. I hope to run again Aegis and compiling Fortran77 code...
Any idea where I can find Aegis (1985-1986) tape backup ? It s more older than Domain_os and I have not see anything on the internet....
Thanks for the help.
Regards
Philippe
Regards
Philippe
