Apple //c monitor
bugman2112
Clifton Park, NY
Can anyone recommend some good literature on composite monitor adjustments? I have an apple //c green phosphor that works great, except the display is a little bent and tilted towards the right. I know there are some fine adjustments inside that I can tweak and would likely fix this. Instead of trial and error, I thought there might be some guidance out there.
Don't worry, I'm aware of the high voltages contained inside these units and I know how to operate inside safetly.
crack it open.. On the inside on the base of the board there is 3 or 4 screws.. all should be labeled. Use an insulated screwdriver and your set
Bugman, let me know if you need another //c monitor. Our museum here in NJ has a few spares.
