Hi All,
So I have a Apple IIe that I have been playing around with. It came with a Microsoft Premium Z80 CP/M card. I finally got the CP/M boot disk down loaded and booted it to CP/M. CP/M runs in 80 columns and it is almost unreadable. Thinking that it was the box I am using to hook the Apple up to a modern LCD monitor I plugged it into the composite port on my Commodore 1902A monitor and its no better. I have tried switching to 80 column mode in Apple Basic and it is just as unreadable. 40 Column seems to work fine. The Z80 card has an 80 column mode, so maybe it a problem with the Z80 80 Column. I have a regular 80 column card, but I haven't tested it out yet to see if it performs any better. I've also tried different composite cables and there is no significant difference.
Is this normal for Apple IIe in 80 column mode or am I missing something/doing something wrong? I know on the old Commodores trying to display 80 columns on a composite monitor was so bad it wasn't supported, but since Apple supported it I figured they had a way around it.
Any input would be greatly appreciated.
Thanks
Gordon
Thanks
Gordon
