The only way I see to proceed on this since you apparently have another //gs and 5.25 drive is with a scope to do side by side comparison of identical functions walking around the pins of the IWM but is it worth it?
The concern would be one slip of a scope probe on the good machine could be disastrous. And even if you determine the chip is bad, is it even available or replaceable? I used to change postage stamp IC's with
a butane pen to heat the old chip leads and lift it. Chips were sometimes also glued down so I had to heat the body enough to melt it. It pretty much destroys the old chip. There were square tips for irons to do the
desoldering but they were expensive and custom sized plus if glued, just couldn't heat enough to melt. The butane pen worked well with just a continuous circling of the chip. That's my experience, anyway ...
Larry G
Larry G
