Are there usable 4004 computer replicas?
Roland Huisman
The Netherlands
I have two boards with National semiconductor 4004 CPUs on it.
These boards are from an EPROM programmer which were built into a development machine. The machines are gone, the original programmer brand is pro-log. But to be honest, I don't care about the original boards, I just would like to do something nice with the 4004 chips on it.
So I was wondering if there are nice 4004 clone projects to built. Or are there any development boards which are worth cloning? And is there any nice software to run on it? Or is it better not to waste my time and put it on display in the display cabinet?
Regards, Roland
cool :) interesting to see the clock on the background. Taking hours and hours to boot or do something interesting...
It is fun, but I think I would like to build something more period correct... :unsure: And no, not a calculator ;)
I guess there is a 4004 monitor from those days. (like for the Intellec MCS-4/40) But is there any interesting software?
There has never been a big community like there was for the 8008
Even though the 1702 EPROMs on that board are awful to program and even to just use for reading, as compared to anything newer, it seems like your board has at least the bare minimum to be used as a simple 4004 system. If I were you I would probably try to figure out if the board generates it's own reset signal or if it needs an external reset signal, and then check the pinouts for all chips (except those that you already know only uses +5V and gnd) to figure out what voltages you need to run the board, and hook a suitable PSU to it, and see what happens.
In particular you could make an adapter that just removes all voltage rails except +5V in order to use newer EPROMs (or EEPROMs, preferably with a ZIF socket, to make the code-burn-test cycle faster).
On your PCB there are 4002 chips that are combined RAM and out ports, and there is a pair of 4008 and 4009 which are used to interface with standard EPROMs, and in some way they can also be used for RAM (but that RAM seems to be addressed in a different way as compared to the RAM in the 4002 chips).
Data sheets for all the 400x chips:
http://bitsavers.org/components/national/_dataSheets/FIPS_dataSheet.pdf
Using the board as-is, is a nice idea. I have piles of these 1702A roms and I have also a reader/programmer for it. I will see if I can find documentation.
My first idea was to clone a sbc kind of board. But I'm not familiar with these boards at the moment...
You have quite a bit of EPROM and I/O ports - but somewhat short on RAM (2 * 4002 = 2 * 320 bits = 640 bits = 160 nibbles of 4 bits each).
Seems good for an embedded system.
Christmas tree lights flasher, egg timer, reaction timer...
Possibly use it for driving a Z gauge model railway...
Here's a board you could build.
Man, that was a heck of a read. You’ve really got to be in it for the love of the game if you’re programming a 4004 to do *anything* today, let alone… that.
It does seem like all the parts are there for any reasonable DIY 4004 project. Transplanting them to a board that would let you use a more modern EEPROM would certainly be better if the plan is to actively play with 4004 programming, but yeah, at least it has those 4008/4009 interface chips instead of being hostage to a 4001 mask ROM.
Oh, I missed that the 1702 also has a weird pinout. In particular only 2 of 8 data lines match later 2716 and larger chips, so would need an adapter that requires a lot of signals.
That is a nice board...
Thanks. It used a 4201 for the clock and a 4289 for the memory and I/O interface. Looks like Roland’s board has the 4008/4009 for the memory interface. Pretty much the same functionality- the 4289 was a combined 4008/4009. A 4040 could also be run by installing it in the 24 pin socket (and removing the 4004 of course.) Handdrawn schematics exist but after 20 years and several moves may take a little digging.
Regards, Roland
You have enough ROM to run Tom Pittman's Assembler on. The code is on bitsavers. I have a real world application that a couple of Garry Kildall's students did but you'd need a lot more ROMs ( 13 ea 1702A's to be exact ), keyboard and a display. It was used to calculate "closest point of approach". It would be used for ships or attack submarines.
I didn't use 13 1702A's though. I used one 2732.
Dwight
Yet another 4004 project...
The write up is on my website at https://www.smbaker.com/scotts-4-bit-single-board-computer-using-the-intel-4004-or-intel-4040 and schematics and gerbers and such can be found on github, linked from that page. Youtube video like usual,
... and a top-down picture of the board:
I went with the 4004 or 4040 (both footprints), 4201 (clock), 4289 (memory interface), and 4265 (peripheral interface). Supports an RC2014 bus connector, a multimodule slot, and for serial either a UART or the bit-bang serial option from Jim Loos's 4004 page.
Regards, Roland
Would you have any interest in selling this :)
