cbc
Hello,
Although I'm a new member, I've been searching this and other places high & low for some information on an AS/400 I have acquired.
It's a AS/400e, 2406-170 model in the larger case which contains additional drives, and what looks like 2 additional Twinax cards in it.
I have in my possession as well the IBM cable 97H7557 which looks to be the correct cable to connect to a Twinax output on the rear and plug into a Windows machine with the client access software installed. Of course, I'm missing the client access software (well if it's on the machine, I can't get to it either yet).
What I gather in my searching is that I probably either need the Windows Client access software, as the Linux version only wants to connect via TCP/IP,, or an actual terminal to connect to this machine. I didn't happen to see a download link from IBM for the Windows software, but the Linux version is easy to obtain.
As it sits, when I turn the machine on, it seems to initialize all the drives, and settles on a code (which I wrote down, but misplaced that notebook!), and the attention light remains lit. It does not seem to complete an IPL, and I'm guessing it's waiting for input from the main Operations Console.
So if I need a real terminal, do I need a 5250 terminal (with associated cabling) to connect to this machine? Or will an "emulator" such as this work?
http://www.ebay.com/itm/Visara-NCT-...871455?pt=US_Thin_Clients&hash=item35c192841f
I've been going over the manuals available from IBM, but I haven't found the doc that says "this is how to turn your AS/400 on and what to connect to it to make it work" doc yet
Most of what I've found describes the hardware and add-on cards, although I am still going over the installation planning doc to see if there is anything in there.
Thanks for any assistance!
Clay Carley
Clay Carley
