Asking for assistance for PS/2 386SX owners on Real Time Clock
alejack12001
Fredericksburg, VA
The machine I am addressing with this post is an IBM PS/2 Model 8555 386SX computer. The machine powered up once several weeks ago for a brief time with errors. Briefly the errors were date, time, floppy, and display. With this post, I wish. To address the real time clock. When this machine was built, its clock was the Dallas clock on chip. Dallas clocks are either difficult to get or they come from China. The one I have is the Dallas DS1287 probably from China. The Dallas is too large for the socket that exists on the motherboard. This socket is directly below the ROM chips. The Dallas has two pins hanging off either end of the socket.
I then saw the advertisement by Necroware for a designed RT clock where the battery can be replaced. The nwx287 RTC Real Time Clock with a small CR1220 battery is what I used on my motherboard to bring for a short period of time the machine back to life. Since that time the machine has not returned to life; I think it might be the floppy drive error. I will post a separate thread on that subject later. I got more batteries for the Necroware. The RT Clock seems to drop the voltage of the battery even though the machine is not in use. Over a week’s time the voltage dropped from 3.3 Volts to 3.0 volts. I am unsure how long these batteries would last over an extended period of time.
I am seeking what other PS/2 owners did with regard to the RT Clock.
Coin batteries will flatten out at 3.0v for the majority of their useful life, it's not unusual to see them floating around that voltage. The Dallas clock chip may drain a battery like a CR1220 quicker than a CR2032 though. I think I remember seeing some Dallas chips being depotted having two batteries inside them in parallel to increase the battery capacity. But you're still looking at several years of run time with a single battery.
As for the floppy drive not working, you probably need to recap the drive. The floppy drives and the hard drives in PS/2 machines are known for leaking capacitors that cause them to stop working.
I have a PS/2 used a 'smart terminal' for my other vintage machines.
I recapped the drives already.
And I found a Dallas clock replacement, but when I installed it, it asked me to load the install/configuration disk, which I do not have.
So... I removed it as just live with hitting F1 during the boot cycle.
But as I said, it has a single purpose, and not really kept as a 'vintage' machine in it's own right. (perhaps it should be)
-J
I saw the Necroware video on his refurbishment of the Model 8555 386SX where the floppy caps were replaced. While his caps were replaceable using his method. I have a physical issue with essential tremor's in my hands that make holding and directing a soldering iron a real challenge; not impossible, but, the probability of error is very high.
The Model 8555 386SX uses a 40-pin floppy controller built into the motherboard. IBM made everything with this model computer perpirtory. The recommended floppy for this model by Electronic Pocket Reference Manual is the part number 64F0162 floppy drive made by Mitsubishi, similar to the one Necroware repaired in his video. This floppy has a 34-pin connection similar but not the same as commercial such as Teac or Sony 1.44 floppy drives. This difference is the connection between the 40-pin and the 34-pin. IBM used a special part numbered 27F4912 cable, which was replaced by 27F4668 because of RF problem with the 27F4912. Finding this cable on the web is impossible. At first, i read on the web an adapter could be used to convert the signals for the 40-pin to 34-pin connector made by Tex Elec as shown in the enclosed picture. I had to make a 40-pin female edge connector to connect this adapter to a commercial floppy. Unfortunately the adapter didn't work. In fact the machine wouldn't turn on, not even the fan until I took this adapter out then the fan back on.
I made a table of the pin arrangements for comparison as shown below. There are voltages passed on a pin by pin basis except for pins 35-40. The pins that are of concern are pins 1 and 4. Pin one shows a reserved setting that would be grounded and pin four is a setting defining the drive type, which is not addressed by the 40-pin connection.
Lastly, my approach is to cut the last 6-pin cable wires and connect the remaining 34-pin ribbon cable wires to the floppy to see if it responds; barring the fact that the caps might be bad.
40-pin Planer Model 8555 34-pin 76x6063 Model 8555 Floppy Drive
PinConnection PinConnection
1Reserved 1Ground
2Hiigh Density Select 2Hiigh Density Select
35-Volts 35-Volts
4Reserved 4Drive Type. ID 1
5Ground 5Ground
612-Volts 612-Volts
7Ground 7Ground
8Index 8Index
9Ground 9Ground
10Reserved 10Reserved
11Ground 11Ground
12Drive Select 12Drive Select
13Ground 13Ground
14Reserved 14Reserved
15Ground 15Ground
16Motor Enable 16Motor Enable
17Ground 17Ground
18Direction 18Direction
19Ground 19Ground
20Step 20Step
21Ground 21Ground
22Write Data 22Write Data
23Ground 23Ground
24Write Enable 24Write Enable
25Ground 25Ground
26Track 0 26Track 0
27Ground 27Ground
28Write Protect 28Write Protect
29Ground 29Ground
30Read Data 30Read Data
31Ground 31Ground
32Head 1 Select 32Head 1 Select
33Ground 33Ground
34Diskette Change 34Diskette Change
35Ground
36Ground
37Reserved
385-Volts
39Ground
4012-Volts
-J
Take a look at this link for downloadable reference disk: Reference disk the disk is an image of PC DOS 5 and the means to configure the machine using 1.44 floppy boot disk. I haven't been able to do this because of the floppy issues on my machine. But if you research some of the youtuber's who have setup their PS/2's and you'll see what the reference disk will display once it boots up.
