BA23 front panel switch replacement?
nadaveiron
Hi folks,
I have a BA23 with a non-functioning reset button. Any idea of a form-factor replacement may be available? FWIW, it's the 6 button variety.
Hi folks,
Are you really sure that the reset button doesn't work? There are two DIP switches on the circuit board that the buttons are mounted on. One of those disables the reset button.
Are you sure the reset button is the problem? The circuit board the buttons are mounted on has two DIP switches on it. One of those DIP switches can disable the reset button.
I am just starting my 11/73 resurrection, I have found that exercising the switches works wonders. In my case, they work fine I just need to replace the neon bulb in the power switch (hoping to replace with an orange LED) and the power button (it's cracked in the middle).
Try working them, and letting them snap out (from the held-in position).
