Battery Spot Welder Recommendations
FazzaGBR
United Kingdom
I'm thinking about refreshing some old laptop batteries by carefully taking them apart, seeing what cells they are, getting them from CPC or RS Components etc. and then having a got at replacing them myself.
I dont have spot welder but have seen things like this on Amazon:
Battery Spot Welder
Are these sort any good or is there a better one you guys can recommend?
Battery Spot Welder
Hi, this one is too weak. Have bought it to repair all kind of akkupacks. Does not work for 18650 cells.
I've got quite a few CMOS batteries that I need to replace and I usually do it like this: https://www.retrocomputing.co.uk/2019/03/how-to-replace-cmos-battery-on-compaq_12.html
I'd love to do it properly using a spot welder but there are so many to choose from I don't want to buy one and it's not up to the job so was hoping someone would already be doing this sort of thing and recommend a particular one or at least certain specifications to get?
Really thorough exploration of the options, but with a focus on larger and higher amperage packs than you would likely be working with:
Something like the SEQURE SQ-SW2 sounds like the thing I am after, just need to find where I can get one from or a similar alternative!
In case it assists:
Yesterday, I used my spot welder on six 10-amp 18650's. My spot welder is pictured below, something that I purchased about three years ago.
