U Unknown_K Veteran Member Joined Sep 11, 2003 Messages 9,075 Location Ohio/USA Jun 9, 2010 #41 I think the IBM PS/2 Model 70's used the 386-16's.
vwestlife Veteran Member Joined May 2, 2008 Messages 5,396 Location central NJ Jun 9, 2010 #42 Chuck(G) said: NMOS had problems running much faster than about 16MHz (and those ran pretty hot). Click to expand... I learned the hard way that a 10 MHz 286 will burn your finger! After that experience I put a heatsink on it. The 286 was a huge improvement over the 8088 in terms of performance. Click to expand... Over an 8088, sure. But an 8086 (or 80186, or NEC V30) system with video and hard drive controllers which take advantage of its 16-bit external bus will be much more competitive with the 286.
