A few days ago I contacted joekster about making an adapter for the P24T in Socket 1 systems. I had already analyzed the Socket differences and found that it basically just needs voltage applied to those extra pins (vs a 486), so it shouldn't be too bad.
He asked me if I'd ever just tried putting one in the board to see what happens, and I said no - I only own one P24T so I'd not risk it.. joekster owns many, so he tried it and it WORKED.
Apparently Socket 2 was just a gimmick - without those extra pins connected to anything I managed to play Quake for a long while, no signs of instability, and the CPU is functioning as though it were a Socket 2 board.
It would seem that those of you who run Socket 1 systems, either by choice or because of a proprietary form factor (as is the case with my Presario 425 systems and Prolinea Net/1) are not barred from running the P24T - in fact, since it has a built-in VRM it works without any modification or adaptation. Just line up the pins in the notched corner, insert, and go!
Edit: For those of you with a Presario 425 or Prolinea Net/1, change jumper 5 to "2/3" for it to not complain about this chip on boot.
