BlackGPiB — Peripheral Emulator for GRiD Compass
vklachkov
Belgrade, Serbia
Hello everyone!
I want to show the BlackGPiB emulator — an experimental emulator of a hard drive, a floppy drive, a printer, and a plotter for any GRiD Compass computer.
Right now, with this device, you can boot the system from a virtual disk, run programs, and write files. The emulator can also retransmit text for printing or commands for drawing graphics to a UDP socket. You can then send this data to CUPS, HP2XX or anywhere else you want.
Here are a few photos and video:
This project currently works on a Raspberry Pi. We are planning to develop a new version based on a microcontroller.
Link to the repository with the code, circuit board, and all the necessary documentation:
https://github.com/vklachkov/blackgpib
As far as I know, until today there hasn't been a single fully functional GPiB bus device emulator. I hope this thing will help bring back to life the Compass computers that didn't get a floppy drive or has died bubble memory.
This project is not only mine but also the work of other community members: Kirill @BOOtak, Anton @usernameak, @JDat, and Kirill from the Belgrade hackspace Xecut.me.
GRiD's peripherals are specific. Other mass storage devices not made by GRiD (HP in particular) are not detected and are not usable by CCOS or DOS.
I didn't mean to imply that any of them would just work.
The point is that HP-IB and GPIB are fundamentally similar and it seems like a lot of people have been doing the same baseline work for a while...
There are few implementation pitfalls in GRiD. By reading HB-IB standard is not enough. Devil is in details.
Commodore used their own flavor of GPIB/IEEE-488 for disks, printers, and other peripherals for the Commodore PET, and there are a number of emulator solutions for that, but there’s the same problem where none of these vendors settled on a common higher-level protocol for the peripherals. So, yes, I would say it’s not really accurate to say that “fully functional GPIB emulation” is new… but a device that does it for GRiDs certainly might be.
This is something I always dreamed of; I have a Compass 1101 that I would love to get programs onto. It currently only has the word processor. At one point I grabbed one of those dual 3.5" HPIB drives hoping it would somehow work... I'll definitely keep an eye on this development!
Well, Commodore could afaik out of the box use non-Commodore printers. HP even had material for their sales people on how to sell HP plotters to PET users, IIRC with examples and whatnot.
The main difference between storage and printers though is that you rarely if ever had drivers ofor particular types of storage in user applications, while user applications had drivers for different types of printers and plotters.
In other words you could most likely connect a HP drive to a PET and run a user program for transferring files between HP formatted disks and the PET, but you couldn't use the HP drive with the LOAD/SAVE commands or for that sake the OPEN/CLOSE/GET#/PRINT#/INPUT# file I/O commands as regular files.
The major difference between Commodore and most others is that the DOS is in the Commodore drives. I.E. they are really file servers rather than drives as seen from the computers perspective. Thus there were simple "dumb" peripheral sharing devices that would just do some bus arbitration for sharing drives and printers between multiple PETs or multiple VIC20/C64/C128's. In practice these were mostly a good idea for sharing devices where you didn't have lots of files open, as the drives didn't have enough memory for more than a few open things at the same time. (In particular the save/replace (save/overwrite) on the 1541 needs every free buffer, and there are three different bugs (!!) that might cause disk corruption when using that feature).
This actually proves the point I was making: GPIB is a bus. Full stop. What GPIB was missing compared to some other busses, like for instance, USB, is a collection of "generic" higher-level peripheral protocol standards. (IE, with USB you have generic device classes like HID, Mass Storage, etc, and within each of those you have subclasses that define a set of APIs that an OS can reasonably write a "generic" driver against with the expectation that a device that identifies as one of these things will support at least this minimal functionality. There's always the option for an individual device to implement enhanced functions if targeted by a more specific driver.) HP selling plotters to Commodore PET users makes perfect sense given plotter language isn't the sort of thing you'd expect to be embedded in a computer's firmware.
As for generic text printers, well sure, Commodore supported those because "support" means little more than the printer being able to respond to the generic OPEN command at a specified device number. It takes very little glue to connect a dumb Centronics parallel printer to a GPIB port; for instance the Osborne 1's printer port is technically GPIB, but they sold centronics printer cables for it that didn't have any active components because if you're not sharing the port with other devices (which would be pretty unusual to be doing with an Osborne) you can basically just wire things so the Centronics printer responds to a transfer targeted at any device number.
I have little doubt that it would be technically feasable to, for instance, write a DOS for the PET (which you'd presumably load via cassette or place in a ROM chip you'd install in one of the PET's empty sockets) that could drive an HP disk drive that speaks the Amigo or CS/80 command sets. I can't imagine anyone ever did it, though, considering how "gold plated" expensive HP equipment was at the time. A Commodore disk drive was pretty expensive because of how overbuilt they were with the dual CPUs and all... but looking it up an 82901M dual drive cost $2,230 in 1983!!!. That's half again more than the fanciest Commodore 8050 cost on introduction in 1980, which itself was hundreds of dollars more than the 2040/4040. Seems like a pretty good reason not to bother.
It is good idea to split into layers GPiB singaling and management in one side, and payload data into another layer. Why GRiD out of box wont work with HP FDDs and HDD?
1) GRiD by default (stock software) have different address assignment compared to HP. This can be fine tuning by changing HP device addressed.
Also there some details on GRiD regarding EOI signalling and GRiD not usin REN signal by default.
2) Payload data format is different between GRiD software and HP. This is the biggest problem. Can be fixed by writing custom device driver for GRiD OS to talk with HP.
Hi, very interested in this project, thanks for making this possible. Any idea when the next board revision is coming?
Well... Sorry, I am too busy now to work on PCB fix with two wrong wires. I also want to make pin header compatible with GRiD flat cable pigtail. Need to double or triple check pinout before proceeding. Any wishes regarding PCB? Change form factor? Move components a little bit? Fix silkscreen? Etc...
At the same time @vklachkov want to migrate form single board computer to microcontroller.
Another sneak peak news from mini chat by @vklachkov:
I have some news.
I'm ~80% done reverse engineering 2102 firmware. I don't know all the states, but the basic logic is clear. I'll publish it on GitHub with photos and schematic from @YL3AKC... I don't see the point in finishing this; I've found all what I wanted.
Along with this, I created a prototype of command for writing disks without Compass. I'll add reading and formatting capabilities a little later... This is created mostly for dumping Yuri's disk, but still.
I'm pretty close to finalizing the code for the Rust version of blackgpib for Raspberry Pi.
But I won't be switching to the Pico version right away. I have several side projects. I have a lot of tasks without blackgpib... Specifically, I need to fix two floppy disk drives so my GRiDCase 3 can be used again. Without that, I can't use it or make any progress on reversing the ISA connector, fdd's are holding me
Thanks for the update and both your efforts, no wishes apart from having something that we can boot a Compass II 1139, because it's stuck on boot so something is wrong with ROM or the internal memory.
It's not urgent but if something moves please update the thread here.
Create new topic or write PM and we can try to diagnose your problem. Usually there are problems with corroded pin headers after leaked battery.
Hi everyone. I haven't been on the forum for a long time. The project is not stopped, and I'm still working on it.
Let me say right away, not all changes have been merged. If anyone wants to use this project in its current state, please take the v2.0.0 branch.
At November, I reverse-engineered the firmware of the original 2102 floppy drive and partially the 2101 hard drive to make sure I'm emulating the devices correctly and to remove all the hacks related to error handling. I have fully reversed all existing commands and responses to them, and now I'm confident in the correctness and reliability of the next version of blackgpib.
Besides that, I've implemented a sniffer mode and created a "laptop emulation" mode, so you can communicate with peripherals directly from the Raspberry Pi. This is needed so that you can write floppies and get disk dumps right from your computer without any extra hardware.
I plan to stabilize the Linux version of blackgpib by the end of December.
The Pico version will come in winter 2026. I've simplified the code enough to make it easy to port from Rust and Linux to C and a microcontroller. The main blocker right now isn't the project itself...
The main problem is that I need to stabilize the tools for working with disks. Yes, there are ccos-disk-utils and GRiDISKCOM. But they have several known issues when working with large disks and a number of bugs.
I have temporarily forked both projects and am actively improving them. But they're not ready for everyday use yet. And that's the most important thing: what's the point of an emulator if you can't work with disk images?)
This is also a major blocker for my other project, GRiDRepository.
When there's news, I'll write here. Unfortunately, I'm working on all of this alone after my day job, so progress isn't as fast as I'd like...
Hello everyone!
View attachment 1311098View attachment 1311099View attachment 1311100
Let's fuse this with FujiNet for network connectivity.
We provide networked and local block devices, as well as virtual printer, and a networking device with tons of protocol adapters.
discord: https://discord.gg/2Ce9guX
It's definitely a cool and much-needed project. But I'm not ready to dive into it and take on another task just yet. My priorities are: blackgpib, grid filesystem, and gridrepository. I physically don't have time for anything else. I can't exactly send a ready-made board to Zurich... But it would be great to use FujiNet on Compass one day.
The project is alive and well. I'm currently preparing a new version based on the Pi Pico microcontroller, which will become the first version for widespread use, and which I will send to my comrades.
A lot has been done over these two months. But the most important thing is that the bug hindering CCOS-disk-utils from working with large images has been fixed, and now there will be no problem creating images for the Compass laptop: whether for MAME or for BlackGPIB.
As soon as I receive the boards, test them, and finalize the firmware — I'll create an assembly guide for anyone interested and will report back here.
I mainly write about the progress in our Telegram chat: t.me/gridcompasschat.
BlackGPIB Pico -- done!
For personal reasons, I haven't posted any news on the forum in a while. But I'm back with the big news: BlackGPIB is complete.
Video demonstration:
www.youtube.com/watch?v=RKgsEGQihvs
While not perfect, a fully functional hard drive emulator for Compass can now be built by anyone. To use it, just solder several components, simply take a microSD card, format it to FAT32 or exFAT, upload the image, and use it. If desired, images can be assigned to GPIB addresses via filenames.
A detailed BlackGPIB manual, along with the release of gerber files and firmware binaries, will be available soon.
That's it! I hope this device will help Compass become more user-friendly.
All source code is on GitHub:
P.S. Unfortunately, CCOS-disk-utils is still unfinished, but I'll try to finish it in June.
