I have now resoldered the four conectors that the card edge connectors fit into in the card cage.
I've also resoldered all the joints (and there were a bunch of them) on the disk controller card.
I'm still getting the same problem, although I seem to get the BOOT ERROR DC message almost 50% of the time. The other 50% is the INSERT DISKETTE message.
The BOOT ERROR DC message seems to pop up more when the machine has been sitting overnight, and less often after it's started up. It couldn't be something like a cap holding a charge and then discharging it, could it?
I'm almost of the mind to start resoldering everything in the Model II - this thing is driving me nuts.
But, I think I need to back up a bit.
The DC error is supposed to be because of:
1)Defective diskette – try a different diskette
2)Floppy disk expansion unit not on –turn on the floppy disk expansion unit
3)Defective FDC Chip or drive – Contact RSSC
1) Maybe the disk I created from an image is no good - ie: maybe the drive I used to make the image is out of alignment or something else. I doubt it, because when the INSERT DISKETTE message is showing, and I insert a disk, it isn't noticed by the DC, and the heads don't load. The odd time that the heads do load, is when I get the BOOT ERROR DC message.
Just to be sure, Druid is going to send me a known working disk. That'll take care of #1.
2) This one doesn't matter as I've got the drive terminated using T3, T4, T5, and T6.
3) I've checked the drive - it works. It could be something on the DC board, but now I've got the original earlier board, and a later board, and neither of them will work in my Model II. It could be two bad boards - doubtful, but who knows?
If, after testing with the known good disk, I find that it still doesn't work, I think my next step needs to be finding someone with a working model II who wouldn't mind popping my DC card into their Model II to see if it's really my board that is the problem.
If anyone has any other ideas of what it could be, or what could be checked on the DC, please pipe up.
Thanks.
EDIT: ADDITIONAL INFO
Good News - sort of.
I tried the newer version DC again.
From his newer Model II, Kevin Adams provided me some info on the cabling for that newer card.
I made a cable, connected the card to the drive, and removed the jumpers at T3, T4, T5 & T6 (the newer card doesn't need termination on the drive).
Turned it on, got the INSERT DISKETTE message, inserted a disk, and then got the BOOT ERROR DC message.
And that's what occurs
every time now ! (No more just hanging at INSERT DISKETTE).
So, maybe it is the disk I made from an image.
We'll have to wait and see. (hey Druid, hellooooo ?)
