fabioNMI
Hello!
I am totally new to PDPs and I just got my hands on a Micro PDP-11/73 with 4MB of RAM and RD53/RX50 drives. RD53 is DU0 and the system is unable to boot from there, the disk seems to be spinning but the error message says it is not ready.
I got some RX50 floppy disks here, some seem to have bootable RT-11 5.01, there is also RSX-11 3.0 and RSX-11 4.0 installation disks.
I am trying to boot via floppy drive using B DU1 (also tried B DU2 for the second half of the RX50).
When I try to boot the RT-11 disks, I get:
Starting system
on my VT101 and after a couple seconds I get the error message:
?BOOT-U-I/O error
000724
I know the "@" is the ODT prompt, but I could not determine why I get the error message. And more importantly: all RT-11 disks give me the same error at the same point!
So I decided to use my 386 with PUTR and it can mount and read the floppy disks, so I believe they should be good?
Just in case I decided to image the disks using IMD and create new copies on DSDD disks, I know that if there is an issue on the disks it will be propagated to the new copy but I just wanted to check whether I can properly image those disks with IMD or not. It seems that I can because PUTR could read the very same directory and files.
BUT when I try to boot RSX-11 v3.0, something else happens, the very first time I tried it, it booted up to a prompt! But every try after that resulted in a kind of loop, after the "Starting system" message the drive keeps cycling reading the disk forever and nothing else happens.
I thought it could be dirt on the drive so I disassembled the RX50 and cleaned it thoroughly (it was super dirty inside) and lubricated the rails, but nothing changed.
I have some many questions! But the main question is: does that sound like an RX50 drive problem? Is there something else I could try? I will try to get some extra RX50 drives for trying but I would appreciate if someone with more knowledge than I (mostly everybody else lol) could shed some light or give me some other ideas I could try.
Btw.: I tried VERY HARD to find RT-11 images for the RX50 but I could not find them anywhere, do they exist? Can someone point me to where I can get them?
Thanks in advance!
Starting system
?BOOT-U-I/O error
000724
Thanks in advance!
