hey all, i am once again working on the p/390 and have been spinning my wheels for the last day or so trying to figure out what is necessary to connect to the card under warp 4. i seem to recall that last time i just replaced all of the aws3274 instances with lan3274 instances, but this is not working for mvs; when i ipl the console connected to 127.0.0.1:3270 (my chosen lan3274 port) does not become active, and ipl fails with a missing master console error. this happens with the local terminals configured as both LOCAL and LAN. i know that under warp 3 cm/2 is used to provide local master/tso console access, but in warp 4 this seems to have been phased out in favor of the TCP/IP connection manager, which has a different configuration process that i cannot reverse engineer. the documentation i have seen indicates that pcomm was supposed to eventually be updated with the ability to directly connect to an aws3274 device, but this functionality seems to be absent in 4.x. does anyone know what configuration is required for either cm or pcomm, or should i just go back to warp 3?
