Marty
Hi All;
Dave, Thank You for Your Response..
"" When you say "Memory location 0007 is changed from 7771 to 0000" do you mean that memory location 0007 'counts' from 7771, 7772, ... 7777 and then to 0000 each time it goes around the loop? ""
I don't know for sure, But, I think So, I will need to look into that closer and try and see for sure..
I will need to run it thru the Loop once and then check that memory Location, and Go into my own Loop to know for sure..
Yes, it is counting up from 7771 to 0000 and then stays at 0000..
"" I am thinking that INDIRECT AUTO INCREMENT is not working. ""
If I knew where this would be/is located, I could do some checking Now..
But, I don't have a clue, where this is located..
THANK YOU Marty
THANK YOU Marty
