I have a Burroughs B38 system which is complete and fully working, including the original monitor, keyboard, and two modules — one containing a floppy drive and Seagate MFM hard drive, and a second separate hard drive module. The system boots and runs BTOS (Burroughs Task Operating System) from the original hard drive.
I have successfully imaged two hard drives associated with this system:
1. A working Seagate MFM hard drive containing a complete bootable BTOS installation in good condition. This is the drive the system currently boots from.
2. A second hard drive with bad sectors which the B38 cannot boot from anymore, but which I have able to image. This drive contained the full suite of BTOS software including COBOL and C compilers and associated libraries.
A larger hard drive in a separate module that does not currently spin up. Its contents are unknown but it may contain additional BTOS software or data.
Is there any interest to publish these disk images and where should I publish these?
Unfortunately the B38 is unable to boot from the most important, second hard drive. This drive worked initially and contained almost all software ever made for BTOS. Now the boot block contains errors and the B38 is unable to boot from the hard drive nor the disk image. I wonder if someone is able to recover the software or read the image to copy the software?
The images where made with the MFM hard disk emulator developed by David Gesswein.
