mc68010
I am trying to install CTOS 9 release 11.3 on a B26 but, running into a problem after install. I get all the way through a Local base install without problems. It reboots and everything is fine. Totally usable system with all the system utilities. The manual says at this point I should run Install and install other disk packages. It claims I should get a Local or Master option menu every time I do. I am supposed to select Local and off I go. However I never get the menu on any package I've tried. Install only gives you one option to specify the file. When I do it runs a few scripts then dies when it tries to copy a ClusterStatus file to the Master. Looks like it is defaulting to Master install or something is wrong in the manual. Maybe both.
I have no docs. Nothing relevant on BitSavers. I suspect the install manual I have a PDF of left out a step somewhere. Maybe some system configuration that is supposed to take place before you go installing additional packages.
