developstopfix
I picked up a 1571 drive over the weekend that was sold as untested. Got it home and it appeared to work okay with one quirk: when powered on before the C64C I had it plugged into the spindle motor would run continuously but once the C64C was turned on and the drive reset the motor would stop and the drive seemed like it was working as it should. I messed with it again last night, this time using an older breadbin, and this time the drive functioned as it should when powered on before the C64; the motor spun briefly then stopped. I tested it again with the C64C and it was back to spinning continuously when powered on if plugged into that specific computer. It doesn't matter if the C64C is plugged into the power adapter or anything else, if the drive is plugged into its serial port and the computer is not running the motor keeps running when powered on. I poked at the serial port and nothing seems out of the ordinary - no shorted pins or anything like that. The only difference I could see between this C64C and the breadbin was that on the breadbin I was measuring about 3k Ohms resistance between ground and the other pins of the serial port, on the C64C it was just above 1k for most of them and then 600-something Ohms between ground on pins 4 and 5.
I don't have any other drives or C64s to test with, and I've never used a 1571 (or C128) before. Has anyone run into something similar?
