| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
I should have everything hooked up correctly DaveThe signals are clearly not TTL levels are they?
So, if the signals are OK with the monitor disconnected, there is something wrong with your hookup of the board to the monitor.
The VIDEO and (I guess) VDRIVE look wrong, but HDRIVE looks OK.
So what have you done?
This is the drawing:Well, you 'should'...
Can you draw out exactly what you have hooked up, scan it and post it.
The problem is the C64 Vic!!!Ok, but what about the other end of the cable (at the PET monitor end)?
And can you remind me what PET monitor PCB it is again - so I can look up the pinout for it.
Dabe
This is the monitor pcbOk, but what about the other end of the cable (at the PET monitor end)?
Dabe
But that signal is only 0.4V pk-pk.The problem is the C64 Vic!!!
On post #232 the video signal was correct!!![]()
Please what can i do now to solve this bad beast???But that signal is only 0.4V pk-pk.
I agree it looks different, but isn't that a function of how you are now measuring it with your oscilloscope?
We currently have a video portion, and a horizontal and vertical synchronisation component, otherwise you wouldn't be getting an HDRIVE and VDRIVE from your PCB.
If you are getting correct TTL signals from your little board, how can attaching a PET monitor to the output of your little board affect the VIDEO and VDRIVE signals if they are not connected to the C64?
If you think it is the VIC chip, either replace it or get another C64... And then we can either move on or wave the white flag.
It may be the VIC chip. Who knows now...
No Hugo on J2 pin 4 i have Vertical drive.JP2 pin 4 is ground , regardless of which way the connector is numbered because it is the middle pin. And it should have no signal on it. But post #2662 shows signal. Something has gone wrong with the connector wiring to the VDU, though if the VDU had not had the about correct H drive signal, there screen would never have lit up.
It is a simple arrangement, there are three active signals and each has a ground connection.
The pin numbering is different at the VDU end, because the plug is longer as pin 1 & 2 there carry the power supply voltages , 8 +9 carry the video, but still on that connector pin 4 is GND too.
yes, i confirm!Hugo,
The connector shown is (I hope) the one that plugs onto the PET logic board and not the monitor!
On J2 your schematic diagram shows pin 4 is gnd, and would be that way regardless if the numbering had got reversed. So how did you end up with the vertical drive on pin 4 ??No Hugo on J2 pin 4 i have Vertical drive.
Hi Hugo, on J2 pin 4 ( on the video pcb project ) i have Vertical signal....Horizontal is on pin 6.... I connected J2 pin 4 with vdu connector pin 3...it is correct, it isn't ?On J2 your schematic diagram shows pin 4 is gnd, and would be that way regardless if the numbering had got reversed. So how did you end up with the vertical drive on pin 4 ??
I have attached a diagram of the connector on the VDU's flying wires, that plugs onto your J2
According to your schematic of your new board, ignoring any pin numbering the sequence of signals is correct and whatever way the pins got numbered, pin 4 is always gnd.
The sequence is gnd, missing pin, Hdrive, gnd, Vdrive, gnd,Video. Its pretty simple.
The unused pin in the VDU plug is blocked off, makes sure the connector cannot get plugged on in reverse, in the correct position the pin is missing from the male half of the connector.
Your diagram on post 2667, if the pin numbers are considered, shows the connections are messed up. It pays to pay attention to the signals and connections, the way the connector is numbered is less important.(for example the Vdrive signal could be said to be on pin 3 or pin 5 depending which side of the connector was labelled initially as pin 1).
On the Commodore motherboard, where the VDU normally plugs onto, they decided to label the connector pin 1 where the Video signal (yellow wire) connects, but your J2 that was labelled as pin 7. It doesn't matter provided the connector gets plugged on in the correct direction, because the sequence of signals match up.
