Hi all - I wanted to reach out in case someone has detailed enough knowledge of the construction of the keyboard membrane on the Cambridge Z88, because I have a curious problem and I wonder if anyone else has seen it.
I bought a Z88 about 4 years ago and found quickly that the membrane was failing, as they are apt to do, so I quickly bought a new replacement membrane from a common source of them and fitted that with good results. I've brought it out occasionally since then, but not for a couple of years until this week.
At first it seemed fine, but then quickly I started to get the '.' key registering repeatedly, and wondered if the rubber mat was failing and sinking onto the membrane... so I detached that, and the issue remained. I disconnected the membrane and the issue stopped, no phantom .......s .
Now: I'm wondering what my options are. Bear in mind this is a replacement membrane, and I've not heard of this problem happening to anyone else. Mostly I read about keys not working/double shift not turning on etc. (I am half tempted to put my original membrane back after buffing it a bit with something, as I still have it and it did appear to work for the first 10 minutes, so go figure?)
I feel like I have isolated the issue to the new membrane. It has had very very light usage in its lifetime, and I can't see anything on the '.' pad itself that might be a short causing this problem. I do wonder if somewhere in the layers of conducting and insulating material there is a slightly worn or shorted area, although I can't think how I would start tracking that down.
So I guess my query is: would anyone know how an issue like this might arise given what these membranes are made up of? (Perhaps it will help others if they run into the same problem.)
