Can you identify this Horizontal Width Coil from ADM-3A?
atod
New York, NY
I think it's snapped inside. I must have broken it with a metal driver. Yes, I should have used plastic, but whats done is done.
Thanks so much
Naughty Boy! If you've still got the ferrite slug (and you should have), you can adjust it by sliding it in & out (possibly holding it temporarily in place with blu-tac) then use your soldering iron (pref on a low temp) to put a few drops of wax round it to fix it more permanently.
Thanks. Is there a standard model width coil that would replace this or do I have to search junk parts?
Your best bet is to find one from a junker or try to rebuild the one you have. Width coils are generally paired with the FBT and yoke. The chances of you finding a new one are pretty slim. Figure out how many windings, the wire size and the pinout and try to go from there.
Also, have a look at the hints here.
It might be that you could use an Electrohome G07 coil as a replacement. They're pretty plentiful. Alternatively, you use one as a basis for rewinding job.
