Can't install Miami_DX on Amiga3000/Workbench 3.1
Sandisk78
Moscow, Russia
Can't install Miami_DX - I need it for a custom made ethernet card. I have A3000 with 3.1 Workbench. When I click to istaller a window appears "Execute a file / Enter Command Arguments" - I click ok it tells "Install_Miami_Dx" is not an executable file / error code 10. Please help, I'm new to Amiga...
I think you need an installer program like Installer-43_3.lha in the same directory as the program you are installing . Figured OS 3.1 would have that.
This is an issue with the icon. Either edit the installation icon so it calls the intended installer, or, since you only need it once, just locate it in the requestor that you are getting.
