Nivag Swerdna
I suspect... and it is only a guess... that in the TTL case the pull-up is to limit in-rush current when the gate is powered up.
| VCF SoCal | Feb 14 - 15, 2026, | Hotel Fera, Orange CA |
| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF Montreal | See you in 2027, | RMC Saint Jean, Montreal, Canada |
That would help answer the question of why, with TTL, pull up resistors were used , rather than connecting the inputs directly to +5V. In cmos systems, they just get tied directly to the supply. Though I do have a number of TTL circuits where the gate and say counter load data was connected to 5V directly but it was not as common as using the resistor.I suspect... and it is only a guess... that in the TTL case the pull-up is to limit in-rush current when the gate is powered up.
I have continuity across G3 PIN9 and F4 PIN10 and in the two pins i have low signalso that suggests perhaps a poor contacts and trace between G3 p19 and F4 p10
They aren't in socket but soldered on board!Maybe de-oxit and wiggle G3 and F4? Check pins of G3 and F4 are happily in their sockets... especially if you fiddled with F4 earlier.![]()
Yes, when i come back to my job this evening i'll check every G3 pins!Can you post all the pins of G3 please?
G3 p19 LO seems wrong to me, especially if G3 p18 is alive and kicking
Thanks Nivag, ok tomorrow i'll try to carefully remove G3 and i'll sold a socketWell... that all looks OK except for p19 which IMHO should reflect p18 i.e. be pulsing.
I think it's worth a 2nd opinion but I would be tempted to replace G3.... although I don't think I have ever seen a single output failure like that before... that being said... flip flops do die. I guess it could be the other end pulling it low?
I guess you could remove G3, socket it, replace with a new one and if pin 19 stays low... lift the leg and see if it pulses.
Ok so need i unsold pin19?? ThanksThe question often comes up when a line is stuck high or low, whether it is the output stage of the IC driving the line that is stuck, or the line being pulled high or low by a defective input. It is almost always the former, because the circuitry at the IC's input is such that it seldom it can fail in a way where there is a very low resistance pathway to +3V , +5V or gnd. One way to find out though, it simply to solder suck just the one suspect defective pin on the IC output and free the pin up in the hole, so it disconnects and can be tested. This avoids having to remove the whole IC which can be more stress on the pcb and might not be necessary.
Hi Dave, welcome back!Piggybacking a signal that is high or floating should work OK. Piggybacking a signal that is stuck LOW is unlikely to work.
TTL logic has an internal pull-up resistor and a transistor to pull the signal line LOW.
For a signal to be LOW, it means that the output transistor has to be switched ON (conducting).
If you put a working device in parallel with a faulty device (with an output that is ON - conducting) then the result will always be LOW (i.e. the working device can never pull the signal voltage high due to the conducting transistor in the faulty device).
Only in a very (very) small number of cases could this work. If the transistor is partially conducting - then the voltage may be sufficiently LOW for the logic (and logic probe) to indicate a LOW condition - but putting an operational chip in parallel may just be enough to 'lift' the voltage up (due to the presence of two (2) pull-up resistors). However, I wouldn't bet on this outcome though...
Bend up p19, insert the current chip and see if it pulses.I removed G3 and i inserted a socket but at the moment i don't have any ls373 spare....
Unfortunately when i removed g3, it brokeBend up p19, insert the current chip and see if it pulses.
