daver2
10k Member
Doesn't your EPROM programmer give you the 16-bit checksum?
unfortunatelyDoesn't your EPROM programmer give you the 16-bit checksum?
I really need you to be able to read the ROM in your programmer and get the programmer software to produce a checksum. Most programmers have that feature. Then we can talk checksums.Ok, i read my eprom and this is file bin that i saved:
ok nothing has changed!OK so what should have happened is "XYZZY" should be displayed in the top left hand corner and then it is read back and displayed in HEX down and to the right.
Can you take a photo of your character generator ROM and for good measure checksum it to prove it is good, please? Replace once done! Re-run the CHARLIE test and check nothing has changed.
Interesting... so what it is meant to do is write XYZZY and then display 58 59 5B 5B 59 and we see 58 58 5B 5B 58 comparing the binary we conclude.. we lose the least significant bit is always being read as zero even when it should be set in the case of the Y character aka 59 aka 0101 1001 being read as 0101 1000. You've got (at least) one bit going missing on the way back!Ok this is DAVE config:
Ok!! Im sure now....bad 244 again!!!!Clue 2: The readback has bit 0 reading back as a ‘0’ and not a ‘1’...
