daver2
10k Member
Ok, so see if it 'crashes'...
So you have already changed F3, F5 and F6 - so that rules those devices out.
What we are left with is either a bad connection somewhere (still) or we haven't waited long enough when we removed the video RAMs (and used pieces of wire to force known characters onto the screen).
If you use your oscilloscope probe on the pins of F9, does it make the problem better or worse?
If you have a mostly static screen (as you do with the PETTESTER DRAM test) you should be able to observe the 'noise' if you know what to look for. Unfortunately, this takes experience that you may not have, but give it a go...
Look at the address lines of the character generator (F10) to see if there is a regular pattern superimposed with a bit of noise.
