Good morning Dave, yes i have nop!Have you got a NOP generator from begore to try?
Yes cpu is in a socket but i have one Nop, what can i do with this nop?Good morning other Dave...
I don’t know where begore came from! I meant before of course ...
Is the 6502 CPU in a socket? If so, it is easy to make up your own NOP generator with a couple of 40 pin IC sockets and a few 1k resistors. I can guide you.
Alternatively, there are a couple of ROM/RAM replacement cards that also contain a NOP generator and my diagnostics. As you are repairing a lot of Commodore PET machines, I would advise purchasing one of these cards as a Christmas present to yourself! It will save you a lot of time in the long run.
Yes on pin40 signal go low and after high!When you say there is a pulse on pin 40, what do you mean? The signal should go LOW at power-up (reset) and then go high - and stay high.
What do you mean by “no signal” on pin 4 (/IRQ). This signal should be HIGH.
It is good that pin 7 (SYNC) is pulsing. This indicates that the CPU is executing instructions (presumably NOPs)!
Hi Dave_m! we're all Dave hereA first test with the NOP Generator:
Using the scope, look at all the buffered address lines from BA0 to BA15 one at a time. Start with BA0, it should be a 250 KHz square wave. BA1 will be half that frequency and so on. This is because the CPU is incrementing through all the address space. You will be looking for something that is NOT a perfect square wave: that would be the problem signal. Probe the ROM that is farthest from the CPU or the expansion connector.
-dave_m
