mutantcamel
- Joined
- Dec 14, 2007
- Messages
- 76
Would you only need a RS-232 if you wanted to use a modem with the CC-40 and another machine? Would it have to be a CC-40 or could it "talk" to a TI99 machine too?
If you wanted to use a Printer/Plotter & WaferTape Drive with a CC-40, would you also need a RS-232?
I've often seen pictures of the 3 stacked on top of each other and wanted to know the purpose of the 232 unit.
Finally can you simply use an Hexbus cable to connect 2 CC-40's up and transfer data between them???
