seaken
The Lo-Tech XT CF ISA adapter came a couple of days ago. I removed the MFM hard drive and the controller from the Tandy 1000HD. I put in the new XT CF adapter and booted. The XUB came on screen and it looked for the master and slave drives and didn't find anything and then booted from the A: floppy drive into DOS 3.3.
So far so good. I didn't have the CF cards yet so I tried hooking up a few old IDE drives. They were not recognized. I'm going to assume this adapter and EPROM are not setup to use regular hard drives. Have to wait to CF cards to arrive.
The CF cards arrived this morning - 2 Sandisk 1GB cards. I put in one of the cards (not knowing if I had it in 180 degrees backwards or not, there are no markings on the CF slot to tell me which way to place the card) and rebooted. The CF card was identified as the master. Slave was empty. Then it stalled at loading from C>C.
I had read up on this and knew I would have to reformat the drive on this Tandy 1000HD and fix the MBR. I had also read that my DOS 3.3 floppy would not work to fix the MBR. So, I powered up my Gateway 486 with DOS 5.0 and formatted a new 720K disk with a basic DOS 5 system and copied over FDISK.EXE. Then I booted the Tandy 1000HD with this newly created DOS 5.0 disk and ran FDISK /MBR. It finished and I then took out the disk and put in my 3.3 disk and ran FDISK from that DOS 3.3 disk. I wanted to use DOS 3.3 to create partitions and format. But it would not recognize the non-DOS partitioning and I could not delete the partitions or create a new one.
I put the DOS 5.0 disk back in and ran FDISK again. Now I could see the partitions correctly (there was one FAT16 DOS partition). I was able to delete the partition and left the card with no partitions. Then I rebooted into DOS 3.3 and ran FDISK again. I was able to create a primary DOS partition and then it asked to reboot. I rebooted the DOS 3.3 diskette and ran FDISK again. It showed a single DOS partition of 32MB as active. I quit FDISK and ran "format c: /s". It formatted the newly partitioned CF card, after which I created a \DOS partition and coipied over all the files from the DOS 3.3 floppy. I got a directory of the C: drive to verify. Then I shutdown.
I powered on the Tandy 1000HD without a floppy in drive A: It found the new CF card and booted into DOS 3.3. Yeah! I did it. I now have a working DOS 3.3 "hard drive" again.
Next, I will use FDISK to create an Extended Partition and use up as much of the CF card as I can for Logical Partitions from D: to Z: I won't get the full 1GB but about 720MB.
Thank you to everyone who gave me tips on getting this CF card for the Tandy 1000HD. I'll miss the noisey MFM drive but this is a good solution - and a hell of a lot of space for early DOS games and applicatons.
Seaken
Seaken
