Chromedome45
Time to acquire a TRS-80 John! To JonB don't take insult but make sure your IC's are oriented correctly. They face each other on the board.
CF Card has power on pin 13/38. Now I'm confused!
If you have an oscilloscope or logic analyser, I would suggest starting by looking at U2 pin 19 (buffer gate, generated by U1) and U2 pin 1 (buffer direction).
- U1 is an address decoder to generate the CompactFlash CS signal (/ADDRSEL in the schematic) at the appropriate port range, hence follows the address bus
- U2 is a bus transceiver, gated by /ADDRSEL generated by U1 and direction controlled by the logic in U3
- U3 generates the CompactFlash /IOR and /IOW signals from Z80 signals /IN, /OUT and /IORQ
- U4 passes the address bus A0,A1,A2 from Z80 to CompactFlash, and also the /EXTIOSEL signal back to the TRS80. This signal is generated by U3 as /IOR OR /ADDRSEL; U4 is just serving as an amplifier to overcome the 150R pull-up in the TRS80
