CHICAGO area HELP NEED - DOS Computer
maceffects
NW Indiana
I have a 386 PC machine that after adding drives (CD/Zip) refuses to boot up from hard drive, gives controller error.
I am looking for someone who is willing to properly configure the machine and download/install drivers to make sure all drives work. I have several CDs, extra cards, etc.
I'm in Northwest Indiana, if anyone is willing to make at least $100 for helping me I would be happy. Also willing to trade your services for some of my vintage Apple Computer(s)/items.
Please PM if interested.
It might save you a bit of money if you would tell the exact configuration of the system. It'd be a shame if someone actually came to help you and discovered that you were missing a critical bit of equipment.
Try removing the drive(s) you just added and see what happens then. A little effort and common sense can go a long way towards resolving the issue.
I actually worked on the machine for several hours, and removed the drives. I'm a Mac guy, I have no idea what I'm doing. I have more than enough extra parts, I'm going to travel to drop the machine off to anyone who can fix. I'd rather fix it my self, but sometimes you need to know when to call a pro.
An IDE cable installed "upside down" can easily cause the symptom you describe. Also, if it's an IDE drive, make sure that it's set correctly for "master" or "slave".
What POST message(s) are you getting?
How far does the machine get into the boot cycle, i.e., what's the last message displayed?
Also, I'd be willing to mail the machine and related items plus pay return shipping to anyone who is vary familiar with these machines.
The thing about a "controller failure" message is that it's almost never the motherboard/adapter. That's because the controller's on the drive itself--basically, what's on the motherboard is a simple bus interface.
20mb, 40mb, 160mb, and 250mb respectively. They work in other machines, so it's unlikely it's something wrong with the drives I have.
So you know the correct c/h/s/lz settings for each of those drives, the cables are correctly connected and you're still having issue in more the one expansion slot? Also the cmos battery is ok?
In the OP you mention the controller error happens only when a cdrom or zip drive is added. If so you don't need to put entries for those in the bios. Leave the entry for anything other than the first IDE hdd blank or set to no drive and the system should boot if they are jumpered correctly.
So... I'm curious about this "adding CD/ZIP" drive thing; how many IDE ports does this system have? As I recall it was pretty rare for 386 class ISA machines to have more than the single IDE connector, usually on a multi-IO card with the floppy controller and serial/parallel ports. Did you try adding CD and ZIP drives serially as slave devices to the same chain as the hard drive, or did you add a secondary IDE controller card? (And if that's the case, are you *sure* it's jumpered as secondary? If you had two IDE cards fighting over the same address I could see how that might make everything go poof.)
It might be useful, since no one here can see what's going on, to take some closeup pictures of your IDE controller(s), the drives, and how exactly you have them cabled and jumpered.
On the subject of jumpers, I do remember that there were at least a few old drives that had different settings for "Master, only drive" and "Master, slave present" and they wouldn't behave quite right if they were in the latter mode by themselves on a chain.
