prime
Hi all,
I've been upgrading / restoring a Compaq Portable II (8MHz 80286) that I have been given. Because it hadn't been run for about 20 years I had to replace the CMOS battery with a new one. It takes a 3.6V AA size battery which I was able to source from Amazon.
However even with the new battery in, the clock doesn't seem to be running, though it remembers all the CMOS setting like display and floppy type just fine.
As an example yesterday I set the date to 2020-10-10 (10th oct 2020), and the correct time, when I turned it on today, the date was still set to yesterday and the time was just past midnight.
The odd thing is if I switch the machine off for a short period it seems to remeber things correctly.
Any clues as to what might be the problem?
Cheers.
Phill.
Cheers.
Phill.
